Trouble Starting
Hey guys, my '94 F2 is having trouble starting. When I try to start it, the engine will either just crank or sputter around 200-500 rpms until I release the ignition button. I've only gotten it to start a couple times. Here's some history on the bike:
Bought in November 2017 for $650 (Whoo!) - When I first purchased it, the bike started right up without trouble and idled well. I left it sit outside until about late March 2018, which I am extremely regretting now. During this period, I did not start the bike or even touch it. This month (April) I started working on it again, first - Replacing the coolant reservoir and flushing out the system due to the reservoir breaking since the P.O. did not use antifreeze. - Replacing the spark plugs After I replaced the spark plugs, I poured some gas where I assumed the intake was, just past the carbs. The bike eventually started, and I rode it around for about an hour. I was driving home just after parking it for about an hour, and I tried to lower the idle while the bike was running. The engine died, and I was unable to get it started again, enlisting the help of a random truck owner to tow my bike home. After this I replaced the oil and cleaned out the carbs. I'm not super sure how to clean the carbs, all I did was take them apart and soak the needles in carb cleaner, blowing them out with compressed air afterwards. I tried to start the bike again after this, but I think I flooded the engine since I decided to give it gas while starting it. Today, after about a week from cleaning the carbs, I fired the bike up again. It started really quickly and idled without an issue. However, after about 5 minutes I turned it off to get geared up, and when I came back out I was unable to get it started. It just sputtered like before until my battery became too weak. I'm going to charge it up and try again tomorrow, but I'm not sure what else to do to ensure it starts up every time. Once it does get started, it seems to run really well. Any advice? This is my first real bike, so I'm not super experienced with the whole fixing process. |
Update: Charged my battery and got the bike started again. The idle screw was too high, however, now the bike has trouble idling. It's pretty sluggish in the 1-4 rpm range, and dies unless I give it gas. I'm going to take apart the carbs again and check out the jets. The only thing I can think of is the first time I was cleaning the carbs, I stripped one of the slow jets, so I grabbed one off of a spare cbr carburetor that came with my bike, in addition to essentially mixing up all the different jets. I read somewhere that each jet is carb specific, is this true? If so, is there a way I can differentiate them?
The jet will have a number stamped into them. It's pretty small so you might need a magnifying glass or zoom i real close with your camera.
If the issue is from idle to 1/4th throttle, look at your pilot circuits. Sounds like they may more cleaning or the fuel/air mixture needs adjustment Also if they carbs aren't sync'd you will have a tough time on idle |
