Torque Specs 1992 Honda CBR600F2
I haven't been able to find torque specs for the stator cover, clutch cover, water pump, oil pan, and other engine gaskets. I bought the cosmetic gasket set and would like to handle it this weekend.
1992 Honda CBR600F2 |
Cylinder head bolt covers - 10nm/7ft.lb
Clutch cover mounting bolts - 12nm/9ft.lb Clutch center locknut - 85nm/61ft.lb Stator coil bolts - 12nm/9ft.lb Oil drain plug (cant find pan spec) 38 nm/27ft.lb No torque setting spec for water pump - tighten securely |
Much appreciated, thank you very much. Will be handling this week in anticipation for MN riding season.
