TIRE SIZE ON F2
I'VE HEARD YOU CAN PUT A 180 ON THE BACK OF AN F2 IS THIS TRUE OR WILL IT RUB SWINGARM OR CHAIN? JUST LOOKING FOR A LITTLE ADVISE BEFORE I PAY THE MONEY!
RE: TIRE SIZE ON F2
actually I thought my tire was a 180 but it's a 160 and it barely fits under the fender... I don't think I could do a 180 no way, unless maybe, maybe I chopped the fender.
But still.... I don't think our bikes need a 180 anyway, they aren't designed for one. |
RE: TIRE SIZE ON F2
F2's have 4.5" rims, 160 is the absolute biggest you SHOULD put onto that size rim. Apparantly 170's and 180's will have issues with the sidewalls folding up on the narrow rims. Later CBR's came with 5" and 5.5" rims I am pretty sure, and THOSE could take wider tires. But other then looks, why waste your money on a 180? Its not like our old F2's need the extra tire and If anything it could cause a degradation in performance and handling.
RE: TIRE SIZE ON F2
160. Nothing more, nothing less.
A. |
RE: TIRE SIZE ON F2
I agree 160 on the rear , a 180 would go but i wouldn't trust it at high speed, and I have heard about some slipping on the rim, your life your loss if if you loose it[X(][X(]
RE: TIRE SIZE ON F2
Also if you put a wider or larger tire or smaller on the back it wont handel as well. That tire is small because it was tested as the most efficent and best handeling tire that they could put on the bike while saving money at the same time.
RE: TIRE SIZE ON F2
THANKS FOR THE INPUT GENTS, A FRIEND OF MINE WENT TO ROAD ATLANTA AND PICKED THE TIRES UP I GOT FRONT AND REAR FOR 100.00 BUCKS I THOUGHT THE 180 WOULD HOLD ME OVER TILL THE FRON BATTLAX WORE OUT THEN I COULD CHANGE BOTH TIRES. I'M ALMOST AFRAID TO PUT THEM ON NOW. I DID RIP OFF REAR FENDER TO OPEN BACK UP A LITTLE AND CUT OFF EVERYTHING ON BACK EXCEPT FOR THE REAR SET. I WISH I COULD POST PICS BUT IT SAYS FILE IS TOO LARGE. TALK TO YOU SOON.
i really don't like to revive old threads but I just want to pitch in on something that was certainly relevant in case anyone else comes across it.
when I first got my bike i (being a novice rider at the time) thought it ran perfectly fine. Really it was good. Later I found out it had a 190 (yes one, nine, zero) in the rear. I switched to stock 2 years later when it started to run low on thread and definitely noticed an increase in handling. for info purposes I went from the battleax to angel gts |
Originally Posted by optytrex
(Post 1293896)
when I first got my bike i (being a novice rider at the time) thought it ran perfectly fine. Really it was good. Later I found out it had a 190 (yes one, nine, zero) in the rear. I switched to stock 2 years later when it started to run low on thread and definitely noticed an increase in handling. for info purposes I went from the battleax to angel gts https://memecrunch.com/meme/SBFZ/i-l....jpg?w=400&c=1 On account of first hand expirience |
Originally Posted by Conrice
(Post 1293904)
"Click the image to open in full size. On account of first hand expirience" with a little broken 'picture' icon next to "click" no actual image. I've seen this a lot but thought it was just something for older threads. Now I think it's me. Knowing me I'm probly doing something wrong.... :icon_screwy::icon_shrug::icon_shrug: |
