throttle stuck
Old 12-02-2007, 12:19 AM
Default RE: throttle stuck
when i took my carbs off to clean them i ran into a similar problem putting everything back together. for me, it all depended on positioning of the cables, it had to be wrapped perfectly around everything in order to get the appropriate throttle response. too little or too much slack both caused problems. if it works without the tank and doesnt work when its on then it is probably pinching the line somewhere.
Old 12-02-2007, 11:56 PM
undercoverbrother's Avatar
as stated above, its pinching the line. take off tank, and air box if you have to and check periodically when puting everything back to see what restricts the cable
spdbump36
04-13-2008 01:59 AM
grobleto
05-22-2006 03:24 AM
ampakes
09-27-2005 07:51 AM
2000cbr600
06-22-2005 03:14 PM
TRBL600RR
06-14-2005 11:12 PM
Quick Reply: throttle stuck
