Throttle Sticks
Old Feb 15, 2009 | 03:38 PM
skatalact's Avatar
Default Throttle Sticks
hey new here, i got a 1994 CBR 600 and my throttle sticks and i wanted to know if any of you guys knew how to clean it
Old Feb 15, 2009 | 05:44 PM
basktb1188's Avatar
i got bug and tar remover sprayed the crap out of it while twisting it back and forth... then sprayed white lithium grease in both cables twisting it some more... now its shooth...
my 2 cents
Old Feb 15, 2009 | 06:28 PM
camaropower's Avatar
If the bike has been over on its right side (as my 900rr was) it may have a bent clip-on, which would cause the throttle tube to bind. Not saying thats what's wong, just an option to check. My brother's 1992 600F2 had just needed the cables lubed
Old Feb 15, 2009 | 08:20 PM
smitty911's Avatar
Lube!!!!
Old Feb 15, 2009 | 09:23 PM
wforeman87's Avatar
What Kinda of Lube or grease. White litheum?
Old Feb 15, 2009 | 09:32 PM
smitty911's Avatar
i have this RK chain and cable lube stuff i bought. its like wax.
Old Feb 15, 2009 | 09:40 PM
basktb1188's Avatar
white litheum grease... but USE bug and tar remover to clean it...it wont eat your cables (NO carb cleaner or strong chemicals)...
Old Feb 15, 2009 | 11:08 PM
Sand.Man's Avatar
If the lube is a heavy wax that may cause it to stick worse... I'd go with an oil based cable lubricant and blow it into the cable liner with compressed air.
Old Feb 15, 2009 | 11:28 PM
wforeman87's Avatar
Default cable lube
Ok Sweet thanks.
Old Feb 16, 2009 | 04:30 AM
And if you do that and it doesn't work, check the clip on to see if its bent, and the bar end to make sure it isn't binding lol
