Swingarm extensions
Is there anybody that makes swingarm extensions for a f2/f3 or do i need to cut off another swingarm and weld it on to mine.
And does anybody have one already extended that they would be willing to sell?
Well if you are willing to I would say that welding your own would be the cheapest most satisfying way to go about it.. As long as you can get some good penetration with your welds, and use the right rods it should turn out.. I would suggest buying sone material that has the same O/D as the I/D of your swinger and just slip it in there and weld er' up.. It would be more structurally sound and would not draw nearly as much as just butting 2 pieces of metal together.. Then you can fill in the origonal axle slot and smooth everything down, Just a suggestion hope it helps!
yeah i was thinking that as well. I was also thinking of getting material that will fit in there and just cut mine and extend it. I found one on ebay already done but i guess it already sold.
600, arm, aswingarms, cbr, exsentions, extension, extensions, extentions, f3, honda, swing, swingarm, weld, welding, weldon
