-   CBR 600F2 (https://cbrforum.com/forum/cbr-600f2-16/)
-   -   Stuttering with constant speed (https://cbrforum.com/forum/cbr-600f2-16/stuttering-constant-speed-98126/)
BlackLion Jul 30, 2009 01:40 AM
Stuttering at constant speed
Hi there,
My bike does have problems with constant speeds.
When I am cruising at speeds like 50mph and 30mph the bike stutters a little.
Like I am playing with the gas constant.
with 30 its stutters harder then 50.
Bike acceleration is fine. The bike drove a total of 17 945 miles.
Who knows what this can be and how I can solve it?
Thanks. :icon_bike:
CaliKush Jul 30, 2009 02:23 AM
im guessin get a carb sync.
BlackLion Jul 30, 2009 03:37 AM
O, and btw. it looks like it happens with between ca. 4500 and 5500 rpm
Dissevered Jul 30, 2009 08:32 AM
Look into the side door and see if there is a piece of rubber above the spark plug wires which goes between the wires/engine and the air box.
After that, take your spark plugs out and see what they look like. Take a picture and upload it here if you can.
BlackLion Jul 30, 2009 12:56 PM
OK I checked the bougie most to the right.
this is how it looks:
http://img263.imageshack.us/img263/7763/99525960.th.jpghttp://img54.imageshack.us/img54/1185/68662259.th.jpghttp://img35.imageshack.us/img35/8435/56018673.th.jpg
SJN Jul 30, 2009 01:16 PM
That one looks good.
Are any of the others black or white, or nice and brown like this one ?
BlackLion Jul 30, 2009 01:42 PM
I don't know yet.
It's hard to get them out the engine.
You get handy in it but it takes a while.
I will check the other 3 another day.
What if they are all good?
oh and btw the cover was sitting a bit loose. the sparkplug don't have a kind of cover but was placed on the screw thread (dont know how its named. i mean the thing were you can turn a bolt on)is this normal?
I mean that thing at the top off the sparkplug:
http://img29.imageshack.us/img29/6004/83305309.th.jpg
http://www.mobikit.nl/atotz/rubriek_2/13/3/get.aspx
SJN Jul 30, 2009 02:31 PM
if all 4 plugs are the same brownish color, then it means the carbs are delivering the same correct mixture in all 4 cylinders. If one is white, it is running lean, or coolent is entering the cylinder. If it is black, it is running rich, or oil is leaking into the cylinder.
The cover on the top is just an adapter, so your leads fit onto the plug.
Some other leads on other types/bikes you have to unscrew the adaptor, for the leads to fit.
SJN Jul 30, 2009 02:34 PM
Here....analyze the condiotion of your engine:
http://www.aa1car.com/library/reading_spark_plugs.jpg
http://www.beru.com/english/produkte...gnosehilfe.php
BlackLion Jul 31, 2009 04:45 AM
So there is a big chance there is one sparkplug not OK deu uncorrect mixture?
What should it else be?
BTW it also looks not running smooth in idle.
