stator help
Old Jun 3, 2007 | 07:07 PM
snapper1978's Avatar
Default stator help
ok i got a 94 f2 with about 30000 on it and the bike kept draining the battery and i would ride for a couple days then have to charge the battery back up,i am thinking it is the stator that needs to be replaced.is there anything special i need to need to be looking for when i do this?i also have the haynes manual for this that i will be following.
Old Jun 4, 2007 | 02:06 AM
CBRider93's Avatar
Default RE: stator help
well what makes you think its the stator in the first place? it could be rotor, a bad battery, or even the regulator/rectifier (which i would check first cause those r the same symptoms, and a lot cheaper also!)
Old Jun 4, 2007 | 02:20 AM
amaank's Avatar
For some diagnosis help check out this thread:
http://forums.cbrworld.net/forums/140473/ShowPost.aspx
Old Jun 4, 2007 | 07:15 AM
wow thanx for the tutorial,that really helps i will do this today
kennygilliam
Dec 31, 2008 11:02 AM
slutty62cont
Aug 14, 2005 01:06 PM
slutty62cont
Aug 14, 2005 03:11 AM
