Stage 1 K&N jet kit HELP!
Ok i am i the process of putting a jet kit in my bike. When i am taking it apart i am looking at the jets. The jet kit wants you to put a DJ122 for stock pipe and a DJ126 for slip on's. The problem is my carbs have a 135 jet in them already! The hole looks to be bigger than the ones in the kit. I might be mistaken but i thought when you changed jets for a pipe the hole was supposed to be bigger. So now i am all confused on if this is even worth my time. Anybody run into this before??? Thanks in advance for the help!!!!
RE: Stage 1 K&N jet kit HELP!
when f2s came from jap the epa was ultra strict on them and tested them at highway speeds in cruising gear i.e. midrange (pilot jet) so honda made em run ultra lean to pass the test they compensated for this by making it rich up top (mains) so in other words youll gain power by leaning out your top and richining up your mid. a side note though all controversy aside you WILL lose power by switching to a k n filter, papper is the way to go.
To answer your question, the Dynojet numbers do not correspond to any other jet manufacturer other than Dynojet. The number on the jet may be smaller but it doesnt mean its hole is smaller as well. There really isnt a conversion chart you'll find. Dynojet has done their research and Cowboy is correct, Leaning the top end and richening the midrange is the goal with a jet kit.
I don't know how this figures into the mix, but my bike had a K&N, D&D slip-on, and AFAIK, a Factory Pro jet kit, with 135 main jets in it when I got it, and it was definitely lean. I wound up with 138s to gt it running right, did a best of 7.29 in the 1/8thlike that, then cut down my D&D and started jetting again. Now I'm at 152s, and so far I've run a best of an 11.36 @ 118.8 mph. Been using genuineMikuni jets though, and I'm not done yet, so far I haven't touched the mids, just the mains, jetneedles, and pilot screwsettings. Next time out will be Jan 11th, we'll see how she does. [8D]
ORIGINAL: Rickracer
