stabilization problem
Old Jul 15, 2006 | 02:52 PM
wheeler6747's Avatar
Default stabilization problem
hey fellas, day after tommorrow im getting new fork seals put on(cbr600f2'94). In the meantime though when i have to take the bike i been noticing very poor stabilization when turning. THe higher the speed, the more it feels like the bike will just slip out from under me if i lean into it too much. Since the fork seals are busted and the oil has leaked out of the forks is this the cause, just the suspension being screwed from it? Or is it something else i need to address? Thanks for your input guys,
Will
MN
Old Jul 15, 2006 | 10:47 PM
Nick I.'s Avatar
Default RE: stabilization problem
you're probably bottoming out causing the front end to "push" and not rebound as it needs to.
Old Jul 16, 2006 | 12:01 AM
ejohn's Avatar
that will do it. what happens is you have good rebound/ compression on the good side and none on the other. this makes the bike forks twest when you put on the break.not good.
Old Jul 16, 2006 | 04:53 AM
frostin's Avatar
and a bad front tire can cause this
Old Jul 16, 2006 | 04:50 PM
lol thanks fellas, well either way shes in their now getting repaired, i just got az new front tire a couple of weeks ago, so i know i dont have to worry about that.
Old Jul 17, 2006 | 12:18 AM
MT Wallet's Avatar
If you can, I would stay off the bike till its fixed.
Doesnt' sound like a good thing for you safety wise or for the bike load-wise.
Old Jul 17, 2006 | 08:31 PM
Ryuu600's Avatar
the feeling of "losing" the front is exactly as previously described. The front suspension is not dampening properly so you get a "floating" feeling from the front. You might also want to check the steering stem bearings because a slight wobble in the head can cause this sensation as well.
kwood
Jun 1, 2020 09:53 AM
hatchtegman
Sep 1, 2010 03:15 PM
Gibby936
Feb 27, 2009 06:11 PM
dewthedoo05
Sep 4, 2007 09:32 PM
Trips
Nov 26, 2006 01:45 AM
