Seized Motor CBR600F2 1993
Here we go. Been sitting for 13 years. Have all the carbs redone and ready. Pulled the plugs, put it in 6th gear and rocked the back tire, would not budge. Could see in the cylinders a little rust. Am going to soak cylinders in PBlaster. Was wondering is it ok to also spray the PB into the intakes and let them soak also? All the values are closed except the two in the #3 cylinder. Thanks for any help on this subject.
Ok Bought some PBlaster sprayed into all cylinders, and the valves intake ports. About 2 hours later took off the Alternator cover and put a socket on the nut. Tapped the socket handle with a rubber hammer. Did this a couple times and it broke loose. Have put more PB in and letting set for awhile before hooking up a drill to turn for a few quick turns. Seems to be turning smoothly.
