Running at higher RPM then usual
Hello guys, I bought my 94 F2 in june of this summer and I love it. I noticed that lately i have been running at higher RPM then before. (ie. BEFORE: at 120km/h run 6000RPM NOW: 120km/h run at 6500RPM) I was wondering if anyone knew what is starting to wear out on the bike? Thanks in advance and if no one has the right answer a push in the right direction would be just as good.
RE: Running at higher RPM then usual
umm i think that it would be opposite if you put a bigger tire on it.... a smaller tire would cause it be at a higher RPM at the same speed, maybe your tire just wore a bunch, i know 500rpm is a pretty big differnce, but im pretty sure a bigger tire would do the exact opposit
Hey guys, first of all thanks for posting all you ideas here. I can't believe that it's sprocket as i didn't change it and it can't be the tire cause I noticed the change in RPMs between one ride to another (a few days apart). Other then the cluch could anything else be worn out that would cause this?
