rectifier
Old Jun 8, 2007 | 03:22 PM
snapper1978's Avatar
Default rectifier
can i put a bigger rectifier on my f2?or is that not good or does it not matter?
Old Jun 8, 2007 | 03:53 PM
bindelsf2's Avatar
Default RE: rectifier
no it doesnt matter..alot of people are using the gsxr 1000 reg on thier F2, there is a write up on it somewhere. i will look for it!
Old Jun 8, 2007 | 04:53 PM
butter0612's Avatar
I picked one of these up... worked great since the only problem has been heat dissipation... Also it mounts right up in stock location without interference
http://cgi.ebay.com/ebaymotors/High-...spagenameZWDVW
Old Jun 8, 2007 | 05:33 PM
bindelsf2's Avatar
thats the one that i have on my bike.. its been a year so far and no problem yet.. i know there is a heat dissipation grease that you can put behind it and its supposed to make a world of difference!
Old Jun 8, 2007 | 07:01 PM
butter0612's Avatar
I used 'Arctic Silver 5' same stuff you put between heat-sinks and processors on computers. High-Density thermal compound.
http://www.arcticsilver.com/as5.htm
Old Jun 8, 2007 | 11:12 PM
amaank's Avatar
gix regulator write up here.
https://cbrforum.com/m_199676/tm.htm
That is for sure what i would do if my reg was out. You can get the gixxer rectifiers for hella cheap on the bay.
Sorry for my horrendous slang.
Also as-5 is really nice stuff, but i'm damn sure you won't need it if you go with a quality rectifier.
Old Jun 14, 2007 | 09:38 AM
richterat83's Avatar
I did the GSXR 1000 Reg/rec on my bike. Wired up no problem and havn't had any problems as of yet. Super easy mod to fix the OEM reg/rec from going out all the time.
Tylor
Old Jun 18, 2007 | 10:13 AM
ALV's Avatar
ALV
Hello!
I had some problems with my rectifier and I changed it with a similar one, made by Ducati Energia. The difference is that the new one had a radiator and ran cooler than the original one. I reckon that the heat was the cause that determined the original regulator to fail.
On this topic (http://www.hondahome.ro/forum/index....&#entry331)I describe exactly how I changed the regulator. I also fitted suplimentary radiators and I used cooling paste (I'm not sure if this is the correct name for it) and so I have obtained an operating temperature of about 20 degrees Celsius lower.
Even though the topic I have linked is in Romanian, the pictures I have made speak for themselves. If you have any questions, don't hesitate: I will answer
graygeezer
Jul 31, 2011 02:33 AM
cbrsingleside
Apr 28, 2010 08:55 PM
rkgjr1981
F2 Tech
Apr 13, 2010 11:46 PM
falieson
Jan 22, 2010 12:40 AM
Junior
Aug 27, 2006 01:25 PM
