Rebuilding a 93 CBR in 2025!
Old Dec 19, 2024 | 01:42 AM
MrEmale's Avatar
Default Rebuilding a 93 CBR in 2025!
Yo~
I want to start by saying thank you. This site has helped me many times.
a little backstory
How I got the bike 2016
New fairings and windscreen after small slide
Added sliders
Added sliders
She was perfect
She was perfect until I left it warming up outside of work
Blew the engine 2019
Left outside for 4 years
2021 Left outside for years
Starting to care
Starting to care
Dropped the engine.
Dropped the engine.
Quick peak under
Quick peak under
Time to disassemble.
Rust!
Rust!
After some wire brush
Marvels mystery and some brushing.
It’s everywhere.
It’s everywhere.
Oil pan
Oil pan
Almost all apart
Almost all apart
Cylinder
Cylinders
Pistons clean up a bit
Still see rust
Still see rust
This is where my nightmares begin.
What even is that
What even is that
I need a chisel.
I need a chisel.
Carbs are even worse
Last edited by MrEmale; Dec 19, 2024 at 02:00 AM. Reason: It didn’t auto save my writing
Old Dec 19, 2024 | 02:53 AM
Ed Harris's Avatar
You’re a braver man than I am, that looks to be a huge amount of work.
What caused the engine to blow up ticking over?
Old Dec 19, 2024 | 07:20 AM
It’s not that bad. Run a couple bottles of seafoam through it she’ll be fine.
Seriously, looks like s fun challenge. It’s going to take a good amount of effort but I bet you will get her road worthy. Keep us updated.
Old Dec 19, 2024 | 10:58 AM
MrEmale's Avatar
I was warming it up after work, left the idle a little too high but then went back inside to grab something I forgot, got stuck in a conversation a bit too long and when I came out the coolant tank was cracked and leaking everywhere. It was a sad day.
Old Dec 19, 2024 | 11:01 AM
MrEmale's Avatar
if I feel it’s getting out of hand I got a mechanic that’ll will make it road ready for $1000
but I think I can do mostly everything. Except timing and carbs gonna need help on that
Old Dec 19, 2024 | 12:15 PM
Ed Harris's Avatar
Ouch, I guess that the fan failed?
Old Dec 19, 2024 | 02:21 PM
MrEmale's Avatar
Valves are removed
Valves are removed
Gotta clean these valves
Old Dec 19, 2024 | 08:19 PM
MrEmale's Avatar
CRc parts cleaner and wire brush
Not terrible
Not terrible
Needs more work
I need to soak this I think
Old Dec 20, 2024 | 07:53 AM
Every credit to you good sir, that is a serious amount of effort and elbow grease that you have put in so far...
Old Dec 20, 2024 | 08:11 AM
i wonder how well a soda blaster would work on things like this.
