Putting on new sprockets tonight found a surprise, need suggestions!
I am finishing up my bike, put the new stock sprocket on rear wheel, torqued to specs.
Took off front and noticed it is a 520 and 14 teeth.
I have a brand new stock 15 teeth for a 530.
For starters I didn't eve know you could put a 520 sprocket on a 530 chain.
Second of all, what will my bike do if I put a stocker on the front?
Down 1 tooth in the front is going to give me better torque right? Well my bike barley pulls the wheel off in 1st so.... im a bit confused.
FWIW my chain that I took off DIDN'T have a master link, that means it stock right???
Basically I dont want to put my stock front sprocket on and have it be a turd...
Thanks
Thanks
99LS1, your bike will feel less grunty now because you went +1 on the front sprocket.
But don't fret, it is BEST to go + on the rear and leave the front alone.
Your chain will live longer with a larger front sprocket as it does not have to wrap around a tighter circumference like it would with a smaller sprocket.
I have a +2 rear sprocket and I find the bike comfortable all around, it's not buzzy at highway speeds and it can out accelerate my friends F2 that is much lighter than mine.
Moral of my long story here is that if you do want to change up the sprockets, add to the rear before you take off from the front
