Plastic Sproket Cover
My f2 was missing the plastic sproket cover when I bought. I went on line (ebay) and bought one, cover, metal spacer and two bolts. If I use the spacer it brings the cover out pretty far and interfears with the shift lever. Can I use the sproket cover without the metal spacer? If so will the sproket/shaft chew up the inside of the plastic cover? Thanks
Thanks guys, I did a little more research. The cover and "guide plate" (as it's called) is OEM. However, it looks like the bike might have the wrong gear shift lever, hence the interference. I just bought another one on ebay specifically for a 93, lets see if that fits better. Thanks again.
