overheating help
Old Jul 29, 2010 | 11:58 PM
ic2283's Avatar
Default overheating help
I couldn't find a drainage screw on my f2 so I just took off the hose and cap. I then checked my fuel pump and it was clean! I want to put water in it and run it a little bit and then drain it again cause my fluid was all dirty. I bought a treatment that will help it out 20 degrees cooler(so I read). any comments??
Old Jul 30, 2010 | 12:04 AM
berga's Avatar
Once I stop procrastinating and buy that fluid you're talking about, I'd like to do the same thing.
Another thing I'd like to add is insulation on the inside of the fairings, specifically the right side. There's a coolant line that goes right by my leg. That gets annoying fast.
I don't worry about the bike overheating, the fan even rarely turns on, and when it does it cools quick. I just get annoyed with the discomfort of the heat. I doubt 20 deg. F is noticeable though.
aan310
Oct 7, 2013 06:34 AM
StriperAngler
Jun 27, 2010 10:15 PM
tommyo4
Jun 9, 2010 05:12 PM
tommyo4
Jun 1, 2010 11:25 AM
98dakota
F2 Tech
Mar 29, 2010 10:10 AM
