oil pan fit????
RE: oil pan fit????
I doubt those other oil pans will fit, but I can't say for sure. Any F2 oil pan should fit though, checkout craigslist and ebay. Alternatively, buy one new from an OEM dealer such as bikebandit.com (link). The oil pan for your bike is $162 and $9.62 for the gasket. Bikebandit offers discounts to AMA card holders (but not much).
RE: oil pan fit????
See if you can find a local welding shop that will work in aluminum. There's a place here in Cheyenne (Wyoming) that would do a job like that for about $20. You just have to be sure to let them know it MUST stay true though. Any warpage would cause it to not seal properly.
RE: oil pan fit????
ORIGINAL: steezin600
i will keep that in mind. thanks. thats a good idea if this othere one doesnt fit... its not too hard to replace yourself is it? just have to take off the exhaust and then unbolt the old one...
RE: oil pan fit????
ORIGINAL: woo545
Exactly...but make sure you get a new gasket and COMPLETELY remove the old one from the block or you will be guaranteed to have a leak. Furthermore, the service manual recommends replacing the seals on the exhaust headers, too.
RE: oil pan fit????
ORIGINAL: Ayres_08
Where can we get the exhaust gasket at. I cant find it on ebay. I just took off my exhaust head pipe because i was completly cleaning the bike over.
$3.36 ea (need 4) for a '94 F2: http://www.bikebandit.com/houseofmot...2-1994/o/m2043
RE: oil pan fit????
thanks for your help guys! it was a crack in the oil pan and i just got a replacement from the junkyard and replaced it. i actually didnt have to take off the exhaust, im pretty happy about that. and there was no gasket on my old one or my new one. just used sealant and it doesnt leak at all. thanks again
