Odd problem..
Old Aug 23, 2007 | 07:08 PM
dcrews's Avatar
Default Odd problem..
Ok, I have a 92 F2, and have the following symptoms:
I just purchased it (last Friday), and rode it home. About a mile or so from work, it died like it was out of gas. I thought uh oh, I forgot to see if it had gas. I shut the key off, opened the gas tank door, and low and behold, I have plenty of gas. I switched the petcock around a few times, scratched my head, then tried to re-fire it.. It started again after 2-3 minutes and ran fine (ish) the rest of the way home.
Today, I took it to work, rode fine all the way to work (around 78 degrees).
Rode it to get it inspected, (90 degrees+) and it died about a mile from work again. Repeat of before, except it took about 4-5 minutes to re-fire..
Ok, fast foreward to me coming home from work.
I was riding home, and it died.. in almost the EXACT same spot as before. Lather, Rinse, Repeat.
Any ideas? I know it probably needs a carb synch, as it tents to 'hunt' for an RPM under very very light throttle (4krpm@40mph or so)
Soooooo yeah.. help me!
Old Aug 23, 2007 | 08:06 PM
MT Wallet's Avatar
Default RE: Odd problem..
I had the same problem, it turned out to be a bad regulator/rectifier and stator.
The charging system was whacked so it would partially charge my battery so I could ride for a while, and then it wouldn't charge enough and the entire bike would stall while I was riding.
I must have pushed my bike home 3-4 times because of that.
My advice: take it to a certified Honda tech, bite the bullet about the price, and have them run a full diagnostic on the charging system, and the bike. It might be something else. [:@][:'(]
Old Aug 24, 2007 | 10:47 AM
dcrews's Avatar
I don't think it's the charging system, because immediately after it dies, I can hit the button and it turns over just fine, just won't fire.
Old Aug 24, 2007 | 12:22 PM
uglyangelracing's Avatar
When it dies open the gas cap and see if you can hear air rush in. If so then you have a clogged/kinked vent tube
Old Aug 24, 2007 | 12:24 PM
dcrews's Avatar
I did that last night, and didn't hear anything.
Something I should mention, work is 30 miles away, one way, so after it does after a mile or 2, it runs fine for the next 29+
Old Aug 24, 2007 | 01:02 PM
MT Wallet's Avatar
That is odd
I am at a loss guys [X(]
Old Aug 24, 2007 | 01:27 PM
dcrews's Avatar
yeah it is odd..
Only thing I can think that may have something to do with it, when this has happened, the bike has been sitting outside on a blacktop parking lot at 90+ degrees. In the morning when I rode to work without a problem, it was mid-70's out and the bike spent the night in the garage...
so something with the heat maybe>?
Old Aug 27, 2007 | 09:21 AM
dcrews's Avatar
any more ideas?
I rode it around some this weekend and it didn't give me any problems, but it was in the garage, not out in the sun..
Old Aug 27, 2007 | 12:24 PM
MikeInCtown's Avatar
Cover your helmet with tin foil.
Other than that, I am at a loss.
Old Aug 27, 2007 | 02:36 PM
dcrews's Avatar
LOL well at least you made a suggestion
ANyone else?
