Octane Booster
This thread will not be closed as long as everyone respects each other, just like every other thread.
With that said, octane increase does not increase performance. Not directly anyway.
Low octane fuel will detonate prematurely at higher compression. Higher octane fuel can be compressed more before predetonation occurs. Its the high compression motor that increases the performance...
If your bike has been sitting for a while, the fuel will lose its octane stability and predetonate. Adding the booster will stabilize it so it will fire normally, thus giving the feeling of more power when compared running on old fuel.
In fact, the less volatile higher octane fuel could reduce performance in a lower compression motor due to it not being at its ideal compression state for optimal burn.
There are other chemicals in those additives as well. Perhaps they are making for the more explosive burn. If you increase things, like alcohol content for example, the burn will definitely be different.
Be careful using them. Your pistons and valves can only take so much of that stuff before they are damaged.
