No Spark!
Old Jun 3, 2009 | 08:42 PM
STBrider91's Avatar
Default No Spark!
I finally got my F2 put together and I went to start it for the first time and it turned over but would not fire. I pulled the the spark plug out and left it in the plug wire and cranked it and there wasnt any spark. Is this a common issue or did I probably just cross something???? I would appreciate the advice...Thank you.
Old Jun 4, 2009 | 08:17 AM
hopz's Avatar
I am new here also so this may be way off the mark.
Before you go tearing into things looking for major problems to fix, be sure you are operating properly.
If I recall correctly, the bike must have the kickstand retracted? Or some such. And be sure the Kill Switch of in the off position.
Old Jun 4, 2009 | 08:34 PM
STBrider91's Avatar
I tried with the kickstand up and down and made sure it was in neutral and what not and the bike still has no spark??? Anymore suggestions???
Old Jun 4, 2009 | 10:44 PM
Squamish CBR's Avatar
The kickstand can be up or down but the thing needs to be in neutal, so there are two switches right there to check as well as the kill switch on the handle bar. Disconnect and check for continuity. Don't tear into anything...carefully disect. Bet you it's something simple!
Old Jun 5, 2009 | 08:04 AM
Sand.Man's Avatar
The bike can be in gear to be started, so long as the stand is up and the clutch is pulled in.
baseballkid
Oct 4, 2012 07:48 AM
cncquinn
May 21, 2011 04:55 PM
jaredaamy
Jan 1, 2009 10:51 PM
Bazman
Nov 23, 2008 01:13 AM
w4kr
Jun 11, 2007 04:44 PM
