no power
Old May 2, 2006 | 02:01 AM
agausepohl's Avatar
Default no power
My bike has sat garaged all winter, typically when i went to start for the first time it had little to no juice. I removed the battery and charged and then put back in. Now the bike has nothing, no lights, no juice, no anything! It's like there is no battery there at all. The battery reads a full charge on the meter and no fuses are blown in fuse panel and main fuse is still o.k. as well. Could the voltage regulator have gone bad? Looking for any ideas. Appreciate the help from all
Old May 2, 2006 | 07:02 AM
MT Wallet's Avatar
Default RE: no power
might be a bad battery-- try using a volt/alternator meter and use a new battery to do this test.
I got one from radio shack for seven bucks
You basically put the meter on your battery terminals when the bike is OFF... and it'll show if the battery is charged or not.
Turn the bike ON now....and put the meter on the battery terminals again..and rev the bike slowly....the higher you rev the more "juice" the battery should be getting and the higher the meter readings you will see.
Since you have a new battery....if you get bad meter readings-- you can probably say it's your charging system that's the problem.
Old May 2, 2006 | 09:21 AM
Krokus_92F2's Avatar
Here is a page or two from the Honda Repair Manual. It will allow you to test your charging system.
Hope it helps. If you need a new reguator, shop around. Price vary from $89.00 to $250.00 !
I just picked one up yesterday from a place called i-bike. My VR went out and cooked my battery. If these attached images are not large enough for you to read, contact me and I'll try to make them available
to you in a larger form that is more easily viewed or I can email you a pdf file if you wish.
Here is the link where I picked up my Voltage Regulator http://www.i-bike.com/store/rectifiers.cfm
[IMG]local://upfiles/6877/B13EF8D6F82C4D34B5CDACA1E65AF331.jpg[/IMG]
[IMG]local://upfiles/6877/7BB6F241D11B4E53A002B2D8E32B862C.jpg[/IMG]
Old May 17, 2006 | 02:23 AM
andref321's Avatar
Not that deep. Time for a new battery.
Old May 17, 2006 | 12:53 PM
furiousf2's Avatar
It has happened to be twice, it's just a dead battery. Make sure to keep your battey hooked up to a "bettery Tender" when you are not riding for long periods of time. I learned the hard way...after replacing 2 batteries.
coolbluedab
Feb 7, 2014 07:13 PM
romanboy
Jan 19, 2013 12:53 AM
__Z__
Jul 14, 2010 10:00 AM
Karmakazi
Sep 29, 2009 09:58 AM
Certified Ryder
Nov 12, 2007 10:13 PM
