new tail ideas?
RE: new tail ideas?
I mounted both a 900rr and a ducati 916 tail to a stock f3 frame. I did both using a vise, drill, and some flat bar steel. mock up thenew tail and use some ingenuity and bend the flat bar so you can mount the tail using mounting points on the subframe that are no longer being used by the stock tail and seat. mock it up and make a trip to the hardware store. don't forget bolts and a can of spray paint. a bench grinder will come in handy to smooth out the rough edges. an angle grinder also comes in handy to cut the flat bar to length. you can pick up a cheap one for about 15 bucks. all together, the tail of your choice, about 30 bucks and a weekend and you got yourself a new *** end.
RE: new tail ideas?
This is my F2.
I modified the very end of the sub frame and bent it up. about where the lower and the upper rail connect. then I installed brackets to make the rear seat secure. I used alot of u bolts, threaded rod. and 1/8in steel strips. I have just uploaded some pics to an album for you guys. These are the best pictures I have.
http://rides.webshots.com/album/558067944QgYOSL
