new cbr digital gauge on an f2...
RE: new cbr digital gauge on an f2...
I don't know the details but
The F2 has a mechanical speedometer and the RR has an electric one so you will need to buy a gizmo that converts the mechanical speedo drive into an electrical signal.
https://cbrforum.com/m_558566/tm.htm
that link really didnt help me much?..i know it can be done without much effort.i have done it on my gsxr its a 93 with a 2006 guage.Only think different we had to do was wire the tach to the coil packs...looking to start this once i get a respone to help get me started..Hopefully tonight
It is best to have the wiring schematics for both bikes when you do this.
To solve the mechanical speedo issue I used a pickup from a 900CBR, you will need a speedo healer to get the correct reading.
You can have a look at what I did here http://www.flickr.com/photos/vallip
I found this some time back on a CBR forum, can’t remember what forum though
When I did this conversion on my bike I found this to be correct but I used the diagrams to be 100% sure.
F3toF4i
Green/Blue Green/Blue
Pink/Green Pink/Green
Black/Brwon Black/Brown
Brown Brown/White
Light Green/Red Light Green/Red
Orange Orange
Light Blue Light Blue
Blue Blue
Blue/Red Blue/Red
Green(both?) Green
Green/Black Green/Black
Yellow/Green Yellow/Green
Yellow/Black Green/White
Pink (solid pink) - ground this out
Brown/Black - fuel reserve sensor -not used
White/Blue - fi indicator - not used.
Red/Green - battery(+) -connect to batteryor black/red wire
F3toF4i
Brown Brown/White
Orange Orange
Blue Blue
Blue/Red Blue/Red
Green(both?) Green
Well I have not played with the 2007 bike but what I have found is that honda dose not change things just for the fun of it.
For example when I installed the speedo pickup from the 900 CBR it had the same plug as the F3 wiring harness had and the same colors as well.
I installed the F3 wiring harness on my bike because I also have the F3 carbs and I wanted the F3 CDI box to take advantage of the TPI sensor on the carbs.
During the installation of the F3 harness I found it to have the same wiring colors as the F2 harness and the same plugs, so that all the F2 stuff, handlebar switches and things like that plugged straight in.
