Neutral light doesnt come on & headlight cuts in and out
Ok so first the headlight cuts out once in a while and its not just the light but the high beam indicator light also goes out so its not the bulb or connector to the th bulb. Any ideas?? And shortly after that started happening my neutral light doesnt work anymore and it wont start in neutral, i have to pull the clutch to start now. These two have to be related i havent had any problems with my bike and these two things happens days between the other. So what do you think
Wiring problem is what it sounds like. Follow the headlight wire both ways and check for nicks/cuts. As far as not starting in neutral if you have a wiring problem that may cause it. You may be in neutral but if the sensor isnt picking it up it may not allow it to start. Check fuses also.
And you are actually in neutral right? lol
WELL I found the problem to the neutral light. The plastic connectors under the seat came undone probably from over time of me riding wheelies and just coming down hard jooked them loose. And i did take the starter switch apart like you all said and didnt look like any thing was touching but i moved some wires around anyway and i'll try it for a while before i put the fairings back on if i dont see a problem in a few days ill attach the fairings and let you all know. so far thanks for the help
