need help
The "strainer" is the filter... lol. Whatever name you want to give it, it is essentially your filter. If you suspect an issue with the filter, just pop off your tank, drain it, unscrew the petcock at the bottom and you will see a plastic tube screen. Clean it and flush the tank.
