Main Fuel: How low is too low?
Old 04-01-2013, 03:03 PM
outsider's Avatar
Default Main Fuel: How low is too low?
My bike started to slowly lose power till the engine died, over about 6 or 7 blocks. I was pretty pissed, since I had just had the carbs cleaned and a new rectifier installed a month ago. Charging system was right up to snuff after the rectifier install, stator was fine also. Anyways, after letting the bike sit after pulling off the street, I was able to start it again and ride the 6 or 7 blocks home. I figured it was the $20 rectifier I got from china, so I bought another one on ebay. The next day, I checked the wiring and rectifier, looked fine, nothing was getting too hot. Couldn't check the electrical system, I don't have a meter, but battery did not seem comprimised. Looked in the tank and it seem very low for not using reserve. I try to keep the tank at least 40 percent full, because I NEVER use reserve unless my life depends on it. This is one way carbs get clogged. I've included a video so you can see where the gas was at just after the engine cut out. But we need to find out why I was able to start the bike after sitting to rule out electrical issues. I do know that if you start the F2 without turning the gas on, you can ride damn near a mile before you notice anything's wrong. Link below:
Old 04-12-2013, 12:09 AM
gpfan1's Avatar
the gas in the tank both looks clean and the filter isn't clogged. Could be the diaphragm in the fuel tap. Normally, the reserve only uses the last 7/10s of a gallon. The tank holds 4 gallons total with about 3 and 1/2 gallons on the main tap. You can pull the vac line off of cylinder #1, plug the fitting, and suck on the end of the vac line to let gas flow. You can use a vac pump or gauge too. If the diaphragm is failing it will not hold a vac or you may taste gasoline, so be careful if you use the mouth method. I use this method to drain my tank when I remove it to work on my f2.
Old 04-12-2013, 09:39 AM
JNSRacing's Avatar
Welcome Crew and ROTY 2014
If the petcock screen, and its sealing O-ring, are intact, then using "Reserve" is nothing to worry about... read this posting I made a couple of days ago:
Petcock Reserve Setting Myth
hawkwind
01-16-2014 09:25 AM
jamescbr87
F2 Tech
04-10-2013 11:26 PM
hurricanematt
01-30-2011 12:06 AM
mlbricker21
03-01-2010 11:05 PM
dalex
04-20-2008 09:49 AM
Quick Reply: Main Fuel: How low is too low?
