Looking for a step by step
I tried using a mityvac brake bleeder and doing it by myself, but it didn't work that well. Grabbed a friend to help and had it done in no time.
I've had good luck with my vacume pump. One of the things I've figured out, go back
the next day for one more pass. It gives the air time to 'settle', so your're not dealing
with micro-bubbles. That second pass is how I get mine to be rock-hard.
I've also heard about folks, (but haven't tried it, myself) that push the fluid in from the bottom,
at the calipers, up into the MC. Makes sense, just haven't tried it yet.
Just don't assume all brake fluid is alike. Be sure to look at the cap on the MC for
the DOT rating. Do not mix-up 4 vs 5, they are completely different chemical bases.
I can't remember who (spicy maybe), published an entire, front brake over-hual post.
With a very good commentary and picture walk-thru. Do a search for that in the how-to
and general sub-forums.
Good luck, Ern
Good luck, Ern
All of this is done with basically large syringes, so you can use them to pull suction on the line if you need to. I'm not sure if they'd be sufficient size for a motorcycle. Maybe a vet supply place has some really big ones.
Any idea on how many ounces or CC's of fluid is in a properly bled front brake system?
CountryRyda
How-To: Mechanical
06-12-2019 07:09 PM
Honda Nut
How-To: Mechanical
03-28-2010 03:04 PM
