Let's talk WHEELIES?
I have a 1994 cbr 600 f2. It has a k&n air filter and a yoshimura rs3 pipe. What are the wheelie capabilities of this bike. I have ridden four wheelers and dirtbikes my whole life but haven't wanted to entertain the thought of pulling a wheelie at high speeds on tar. Is this bike able to pull it up just using the torque or must I be at high revs? What gear is optimal for the wheelie and how many gears will this bike wheelie through. Another concern of mine is bringing the wheel back down, if it slams will I lose control. I am going to keep the front end down for now but just testing the waters.
RE: Let's talk WHEELIES?
Sounds like you're pretty new. I would advise against it...but you'll most likely start doing it anyways.
I have a pipe/filter/jetted, and -1 sprocket up front w/a 520 conversion. The latter makes the most difference as far as wheelies are concerned.
Start getting a feel of the front wheel coming up. Start slow in 1st and progressively roll the throttle harder. Do it over and over.
Sooner or later the front will start lofting....get comfortable w/that.
If you just want it to come up, you can roll it maybe 2/3 full throttle from low rpms...when you get to 6k (give or take), roll off hard and roll back on hard. This has to be done extrememely quick or you'll get lackluster results.
WARNING! IT WILL SHOOT UP QUICK, ESPECIALLY IF SEATED FARTHER BACK W/AN EMPTY TANK!
Problem w/these type of wheelies (power wheelies) is that you're accelerating...and thus "chasing" the wheelie...and balance point...makes it hard to get it @ the balance point and keep it there. Slow it back down and it comes crashing back down taking a toll on your fork seals and head bearings.
Clutch up in 2nd. Not that easy, not too hard. Low gas, scoot back....roll it WOT in 2nd....around 5-7k just touch the clutch while continuously going WOT. If if doesn't come up you probably clutched it too long (Just a dab!) or kept the throttle constant if not rolled off. WOT!
Be careful....take your time. No more than a few minutes clutching it as it'll wear out your clutch quickly.
I would just practice a lil here and there. Its easy to loop in 1st, I don't care what anyone says.
Practice getting your right foot @ the rear brake so you can modulate the height. You won't do it initially as you're just getting used to the front come up and you'll be rolling off artificially early.
2nd gear is good for about 75 mph indicated for me....would be fine for hwy wheelies but I don't think I can start @ 55....I think around 35 or 40....
A.
A.
i just learned to wheele on my bike a few weeks ago almost lay\ied it down in the prosess but im learning i jsut get the bike up to about 7 grand and let off the throttle till it hits 6000 or 6500 rpm and go to WOT and hang the hell on it will come up quick im stilll working on riding the wheelie but i can get ti to go through first...ride safe...ride fast
ORIGINAL: 02_GSXR_HYBRID
gwt a newer, lighter, more powerful bike and wheelies are effortless. my 02 1K comes up on accident al the time in 1st-3rd gear.
