Let's talk about lightening a Crankshaft
Old 02-23-2015, 07:36 AM
Default Let's talk about lightening a Crankshaft
I am needing to swap out my transmission gears and fork. Thought about lightening my Crank while I am in there. I know CBRzone(APE) will do it for $225, but is there anything else I need to do other than drop it in(of course time it) and go?
Plus, what is the weight of the OEM Crankshaft and how much should the shave off?
Old 02-23-2015, 08:33 AM
Conrice's Avatar
Replace your bearings! You need to ask them specifically what they're going to do to it. I know Falicon automatically checks to see if the crank is straight (straightens it if need be), and they clean and polish the journals.
If they do all of that, I'd measure everything with platigage to ensure proper clearances for your new bearings.
If they say they're not going to touch the journals, you'd probably be safe to just order new bearings according to the key Honda has in the manual.
Old 02-23-2015, 09:20 AM
I was informed that I need to balance my motor(pistons, rods, flywheel, etc.) too, is this true? APE said they lighten your OEM Crank 2 lbs. and they send it back to you. Is that too much?
Old 02-23-2015, 09:30 AM
74demon's Avatar
Yes. Do they do it there?
After it's been lightened, you want to make sure the all the rotating parts are balanced together. The rods should be resized to make sure they're round and all are the same weight.
Less rotating mass will make the bike turn easier. It's a great mod if you do it right.
Old 02-23-2015, 09:43 AM
Does anyone know what stock weight is on the crank alone?
Old 02-23-2015, 09:53 AM
Conrice's Avatar
Yeah, if you don't have it balanced, you'll get vibrations and it won't last as long. It'll have uneven bearing wear.
2lbs is quite a bit to take off a sportbike crank.
Old 02-23-2015, 09:55 AM
Conrice's Avatar
Don't know the exact weight, but I'd say its somewhere around 22-25 lbs. (If you were looking for a rough estimate)
You need someone who has weighed it on an accurate scale.
Old 02-23-2015, 11:19 AM
So looking for crank bearings on Bikebandit.com and they offer 4 different bearings for the crank but only one number for microfiche illustration. Which bearings do I need?
1993 Honda CBR600F2 Parts, 1993 Honda CBR600F2 OEM Parts - BikeBandit.com
Old 02-23-2015, 11:58 AM
74demon's Avatar
Its's not loading the diagram for me.
But, wait to see if they grind the crank at all before you order them. When I have sent cranks and rods out to have work done in the past, they come back with the correct bearings.
Old 02-23-2015, 12:10 PM
Phil314's Avatar
Different bearings are for different clearance. They are listing 4 different sizes/colors. It also depends on if they resize the journals on the crank. You won't be able to do anything until after the crank work is done. This is for honda cars, but it explains it a bit more. You'll have to plastigauge it, do the math and then order the right color/size.
OEM Honda Crankshaft Main Bearings
Quick Reply: Let's talk about lightening a Crankshaft
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
