Just bought my F2 Need help
Old May 17, 2007 | 05:08 PM
LibyaCBR's Avatar
Default Just bought my F2 Need help
I just bought my first bike 1991 CBR 600 F2, and i need some maintenance advise. The bike seems to run fine, but i think i should get an overall tune up done.
Does anyone have any advise on what to get upgraded, what parts need tuned up, how much an overall tuneup will cost?? Also, should i try to find parts myself and install them or go to a dealership?
Thanks!
Old May 17, 2007 | 06:32 PM
gixxereater's Avatar
Default RE: Just bought my F2 Need help
USE LARGER FONT!!! LOL.
Do it yourself. Change the oil/filter.....replace the plugs.......replace/clean air filter.....lube all cables and adjust properly.......clean chain or replace chain/sprockets if bad......if you do that then gear it down a little say -1 up front. Bleed the front brakes.....check the pads/replace if necessary.......replace the tires if they are old (that will make it feel like new again)............wash it...............set static sag for YOU.........check all the lights over and make sure they work.........adjust the shifter to fit where it's comfortable to YOU..........enjoy!!! Take the MSF......or sign up for a track day...........that will improve your riding 10 fold in a weekend.............
Good luck
Old May 18, 2007 | 01:48 AM
C2H5OH's Avatar
http://www.sudco.com/apeCamchain.html
Old May 18, 2007 | 12:19 PM
LibyaCBR's Avatar
Thanks for the help guys.... Any advise on where i can buy all these parts? Do they sell them at dealerships or do i have to order all oniline?
Old May 18, 2007 | 12:23 PM
LibyaCBR's Avatar
Also, it takes my bike around 6 tries to start if its been sitting idle for a day.... I this normal for a carb bike? Is there a way to improve this?
Thanks in advance!
Old May 18, 2007 | 01:19 PM
Dan1220's Avatar
did you flood the carbs maybe?
superlund
Oct 18, 2010 07:35 PM
allnightsurfsesion
Aug 5, 2010 07:36 PM
gsingletary
Jan 20, 2009 12:13 PM
900rr_Guy
Jun 17, 2007 09:42 AM
CDUBYA
Feb 9, 2007 12:43 AM
