I'm about to climb the bell tower...bike won't start
I had it running about 1.5 months ago...but now it won't start. I had the carbs cleaned/synch last summer, I have pulled the plugs and cleaned them...nothing seams to make the bike turn over. Today, I tried to see if I was getting a spark...I couldn't tell...how do I check? before I take it to the shop, any ideas???
RE: I'm about to climb the bell tower...bike won't start
To see if the spark plug wires are working/sparking take one of them off the plug and stick a srew driver in it. (Be Careful) While holding the plastic end with thewire on it, touch it to the frame. If u see a spark (tadaa), only reason to be careful is because it will shock u, nothing harmful just might scare u.
I just went and looked at my bike and,
Here is placement of cylinders | #1 #2 #3 #4 | (Setting on the bike)
Right Igntion Coil (Top = #1 Cylinder) (Bottom = #4 Cylinder)
Left Ignition Coil (Top = #3 Cylinder)(Bottom = #2 Cylinder)
Lmk if its wrong, i may have of looked at the cylinders wrong, (Pretty Sure Im Right Though)
