ignition wiring... for a alarm
i am installing an alarm and just need a little help. everything is hooked up except the ACC wires. i need to know what colorand where the following wires are at.. thanks in advance
1)the acc wire on the ignition switch
2)the ACC wire/ starter kill linefrom the stator to the ignition switch
3)the engine start line..
i would meter them but i dont have my key because its with my tank being painted... so i need help..thanks
RE: ignition wiring... for a alarm
Solid Red
? not sure about this one, better description?
Yellow with Red stripes
Should be able to find all of them on the front fairing stay under the gauges
Solid Red
ORIGINAL: pbrownw
he had a a THICK accent so it wasnt that easy to understand...
probably the same one.. option group..like 35.00 on ebay..
http://cgi.ebay.com/ebaymotors/ws/eB...675&rd=1,1
now that i think of it and look at the diagram i think he said to cut the starter switch wire (off position) and the pink goes on the side of the ignition switch and the grey goes on the lower(motorcycle side) does that make any sense?? because it hasa anti-hijack feature so you can disable the engine if someone jumps on the bike while its running. and a starter kill feature.. so that makes sense to me but i need a 2nd opinion on that..
the pink and the grey are the only 2 that i am confused abouti may just have to call him back and double chek
