I picked up a tidy F2!
Spent ages searching for the right bike but finally got one last weekend. Pic when I learn how to upload one. There's a problem with the headlight though I got it for a cheap price privately. The guy said he changed the headlight bulb but the light still won't come on? The engine sounds very good and we're going to give the whole bike a thorough service so it's ready for spring. On the whole I'm very pleased with it.
To upload you'll need to put the picture into imageshack or photobucket and then use the [IMG] [/IMG] code. You can also use the upload button through your manage attachments at the bottom of the screen when you do a message.
The headlight issue, have you checked the fuse? If it's not blown and the buld is hooked up correctly trace the wires back and make sure none of them have worn the rubber insulation off and is grounding itself out on the frame. Best of luck!
