How often to change the oil
There will be as many different answers to this question as there are people who answer it. You need to look at how you ride and what kind of oil you're using as well. If your using the upper tach range alot, obviously your oil is going to break down a lot quicker and you will require oil changes sooner and if you're using a fully synthetic oil, you can go longer between changes because it resists viscocity breakdown better. I personally, do it about every 1500 miles and don't use synthetic oil. I also change the filter every time I change the oil.
