High beams work Low Beams Dont?
Just as it says in the title my high beams work but if my switch is set to low beams i have no head lights any ideas?
My bike had that problem - two possible answers
1 The low beam switch needs cleaning inside - corrosion 2 The low beam filaments in your bulbs may have gone. This happened to me after 2 years use, as I ride on dip all the time. 3 Other wiring problem - wire damaged, fuse etc Good luck :) |
i bet it's the bulb, it's an H4 halogen bulb. same as what cars got so you can buy them at an auto parts store. ~$10
| All times are GMT -5. The time now is 01:36 AM. |
