Help with F2 wiring
I am just putting engine back in my bike and got all the wiring hooked up but it wont turn over i got power to the fuse box for the starter button my question do you think the starter silenoid is bad. any help would be great.
Thanks Brian |
RE: Help with F2 wiring
It cranks, but it won't fire? Or nothing happens at all? I know this is elementary, but do you have the red RUN switch in the "run" position? Is your battery fully charged? What exactly are you doing, and what exactly is happening?
Also, don't forget that it won't start with the kickstand down, unless it's in neutral. |
It wont turn over or anything and i have the switch on i have did that before sitting somewhere lol. I have power on the side of the sileniod but when i hit the start button nothing goes back to starter
Sounds to me like it's either one of 2 things: starter solenoid or starter switch. Since I don't see the actual starter switch going bad, I would check the solenoid.
Is there a way to check the sileniod to see if it is good
