!!!HELP Engine Runs Hot HELP!!!
Old Apr 25, 2007 | 09:49 PM
AlpineCBR600's Avatar
Default !!!HELP Engine Runs Hot HELP!!!
So my 93 f2 with 35.000km's on it is running hot, So I flushed & changed my rad coolent... problem did not go away.. My bike seems too run normal just gets alittle hot at lights or when I let it idle for abit.. It hasnt hit the red zone yet but it gets intoo the 3/4 temp range this is when my fan clicks on is this safe?? will my bike get damaged..?? should I worrie..? .. when im riding my bike the temps in the 1/4 range which is totally normal.. does anyone have any ideas... I just dont want too damage my engine when warmer temps come.
I checked my oil before and after I changed it.. there was no coolent in there.. so thats the head gasket out of the question * thank god *
what I did notice tho was bubbles forming in the coolent reserve.. but that has calmed right down.. im guessing because there was or is.. air in the rad after the coolent change..
Guys im out of ideas and money.. any ideas would be great!
this is what I have done to my bike so far ( below ) summer ready except for the heating issue
- Rad flush & coolent change
- Oil Change
- plug & wire change
- battery change
Old Apr 26, 2007 | 02:34 AM
lee1rbc's Avatar
Default RE: !!!HELP Engine Runs Hot HELP!!!
Check aroundat some other posts, 3/4 is very normal, that is the temp that thethermostat opens and then the fan kicks in.
Old Apr 26, 2007 | 11:55 AM
TennesseeCBRF2's Avatar
My bike does the exact same thing. As long as your coolant is clean and you have no air pockets in the cooling system you should have no problems. 3/4 of the way up the meter is normal in stop-and-go traffic. I think you're fine!
okibi
Sep 22, 2010 10:17 AM
quadracer18
Apr 27, 2008 01:14 PM
lee1rbc
Mar 28, 2007 10:18 PM
123svt
Aug 15, 2006 01:18 PM
