Help Clutch Stuck Engaged!
Well to begin with my bike has a very hard time starting in the mornings, Factory Jet kit and slip on are the only mods.
Bike starts instantly on choke, idels fine for a couple minutes and dies, if I leave the gas off for the warmup and ride for a few on choke then with the gas on its sometimes fine.
Well this morning it wasnt fine, it stalled out which Ive found the only reasonable solution to is a roll start after that it will usually start right up and be fine no problems ever again.
This morning the Roll Start didnt work so I push the stupid bike back up the hill to my house go inside for a break ( so I didnt just shoot it ) When I come back out I try to crank it over and no beans, so ok one more pust start I put it into gear, pull in the clutch (which feels perfectly normal) and go to start pushing it down the hill for another roll start and the bike wont roll forward. The clutch is still deffinatly engaged. I tried to adjust the clutch at the lever but it didnt help at all.
What could have happened while I was push starting that would kill the clutch or cause it to become stuck?
Thanks in advance,
Morgan
Thanks in advance,
Morgan
jboice06
09-09-2008 09:43 PM
