headlight problem
Old May 24, 2009 | 01:30 PM
77vetteguy's Avatar
Default headlight problem
my headlight went out last night. the bulb and fuse are fine. im getting power across the fuse, but no power at the plug. If its the switch how do i test it?
Old May 25, 2009 | 01:31 PM
dereckjt's Avatar
Oddly enough I had the same problem last week. It may not be the same resolution but it try it out. There is a three way switch under the starter button that when you start your bike it deactivates the power to the headlights, and when you release the starter it swithces power back to the headlight, anyway when I checked mine the connection had broken and the soldering had gone bad. Give it a try, it might be your problem.
Old May 26, 2009 | 09:22 AM
chuckbear's Avatar
I've experienced something similar too. If it happens again, make sure your starter switch is all the way out. When you engage the starter, it shuts off your headlights/running lights, and if it's sticking it will keep them off. I notice this happening on my bike from time to time and that may be happening for you as well.
Old May 26, 2009 | 06:21 PM
77vetteguy's Avatar
thank you that is the problem.
cajun rider
Mar 22, 2012 07:37 PM
rnora1
Jun 11, 2009 10:28 PM
bottlebaby
Jun 4, 2009 09:38 PM
josemiguel
Oct 20, 2007 09:06 PM
