Have no clues what it may be
When I go above 5000 rmp (no matter which gear Im in) my bike makes a really loud noise(I thought its from the engine), its not knocking (althought thats another problem that I have when its cold only) but its sounds mean. Somebody told me that it may be just the muffler.What do you guy think. This is my first season and first bike. Its not in a bad shape but I already had few incidents with it. I decided that Im gonna keep the bike anyway, and try to fix things up (winter project). Do you guys have any tips what should I work on/ look in to especially.
Thanks,
Trish
Thanks,
Trish
RE: Have no clues what it may be
like Ehonda said, CCT, I'd replace it before living with it... live with it too long and your cam chain will slip a tooth and blow your top end to bits.
www.aperaceparts.com
Ape sells the manual cam chain tensioner for about $50, it's an easy install and can save you lots of $ in the long run. Unlike the OEM CCT, the manual CCT will never fail if installed and set up properly.
ORIGINAL: Cadaver
It also won't automatically adjust as the chain stretches due to time and/or heat. And, how can you guys possibly diagnose CCTL with "a loud noise." For all we know, it could be a backfire or a freakin fart.
The CCTL wasn't really a problem until the F4i, then everyone jumped on the CCTL bandwagon.
Plus, I'm sure not "almost all" rectifiers burned out. If so, I have one of the valuable rare unburned ones!
Maybe if you could describe the noise better and walk around your bike and try to give a general location of the noise, we might be able to diagnose it better.
