Handlebars
My main question is about the inside of the handle bars. There is a piece of tube shaped metal that has a thread inside the CBR handle bars (Supposing it is used for bar ends to screw into) Ive only been able to remove one on my F2 but the other is stuck and need to look for a replacement. My question is, what are they called? Do they have a specific name to them?
1 Attachment(s)
The metal tube inside the handlebar is the actual bar weight not the bar end as most people believe.
Attachment 27142 There's lots of vids on youtube about how to remove the weights, here's one. the main problem usually is that they are badly corroded and therefore very much stuck in there and some force is needed to yank it out. The question is why you want to remove them? Replacing them with any of those expanding rubber thing aftermarket types is a downgrade and you can get new ends from ebay in any shape and all the colors of the rainbow that has the step and will replace your original bar ends. |
Originally Posted by Mattson
(Post 1293435)
http://i26.photobucket.com/albums/c1...OP20BRIDGE.gif https://youtu.be/_JAOqzD7McQ There's lots of vids on youtube about how to remove the weights, here's one. the main problem usually is that they are badly corroded and therefore very much stuck in there and some force is needed to yank it out. The question is why you want to remove them? Replacing them with any of those expanding rubber thing aftermarket types is a downgrade and you can get new ends from ebay in any shape and all the colors of the rainbow that has the step and will replace your original bar ends. |
Honda 53104 MV4 000 Weight B Handlebar | eBay
However those seem to come without the rubber rings and the locking clips. I'd reckon if you can somehow force the old ones out you could refurb them with a splash of paint and get new clips and rubbers from your local honda dealership parts department. Got a pic of those bar end mirrors of yours? What sized bolt do they got? I gotta do some digging in the garage before promising anything... |
Ok so this is my project so far, the bar end mirrors not available in these but I will have to update when it is light again. Now my biggest problem is cutting the wiring loom to size as i have to much of it now :P
https://scontent-lhr3-1.xx.fbcdn.net...78&oe=57294FC1 https://scontent-lhr3-1.xx.fbcdn.net...e6&oe=5739EA98 https://scontent-lhr3-1.xx.fbcdn.net...07&oe=57400603 https://scontent-lhr3-1.xx.fbcdn.net...1c&oe=57357500 |
