Fuel Gauge?
RE: Fuel Gauge?
1. Open Cap.
2. Look inside.
Fuel gauge
But seriously, any modifications to gas tanks should be done VERY CAREFULY. Gas tanks have been known to explode when welded on, even after being emptied and cleaned out. And if you drill holes, there's a chance that it'll leak (onto your hot engine) if you don't seal them up properly...
OTOH, you have a reserve anyway, so as long as that's working I wouldn't imagine getting stranded. And it's not like it costs that much to fill up a motorcycle.
2. Look inside.
Fuel gauge
RE: Fuel Gauge?
On cars, the fuel level sender is a pretty big piece of equipment, which is also the reason that cars have a much larger access hole on top of the fuel tank (to install in-tank fuel pumps).
If you wanted a low fuel indicator, that would be pretty painless (tap a hole and thread in the gauge, seal with RTV or thread sealnt), but a fuel level gauge would be a bit more complicated. You'd need something very compact that will mount to the cap base that fits through the fuel filler hole (which I would imagine is less than "3 wide)...
Either way, a level gauge probably isn't worth the effort.
RE: Fuel Gauge?
ORIGINAL: SpecR
I had a heck of a time with my wife's Yamaha because someone had used red RTV silicone on the carb bowls to hold the o-ring seal in place. BAD idea! The gasoline ate the silicone up and it swelled over into the bowls, THEN it got in the jets and the bike wouldn't run worth a crap and we were about 30 miles from home. I had to pull tank, airbox and carbs off, disassemble the carbsand spend about an hour or two scrapping that crap off the sealing surface of the carbs and clean it out of the jets. That was a freaking mess! Gasoline and RTV silicone do not go together!
CBR13F2: Why would you need a fuel gauge? Open the cap and look inside like SpecR said or do like I do: Fill it up, reset trip meter, ride till you have to hit reserve and note the miles you traveled from fill up to reserve. Then every time you fill it up reset your trip meter and you'll know how much farther you can go. Alot easier than cutting or drilling into the fuel tank.
