Finally Got My F2!!
Finally Got My F2!!
Yep, finally got my F2 - rode it to work the other night... sweet ride!!
But now it doesn't work...(aka the story of ALL of my vehicles)
Any ideas??
Here's what's happening:
It won't start. Ran fine the night before, but when I went to start it the next day... nada.
Electric works - have lights, etc. Starter works - have it turning over. There's gas - that
I'm sure of, cause I can smell it - a lot of it. But nothing beyond that.
I haven'tordered the owners manual yet, though I found the link from this site to the Service Manual PDF, and downloaded it. eBay has a manual for a 93, mine's a 92 - should be the same right?
My car experience suggests that it's flooded. And since I've only recently become aware of that it has agas tank switch, I'm guessing that since it was left ON, that it maybe flooded the engine. Do you have to turn off the gas tank after each ride?
It's been sitting since Saturday (with the gas tank turnedoff), and unfortunately haven't had the time orgood weather to do anything with it for the past couple days. Tomorrow is my day off, and the weather looks like it might be kinda nice -would love to ride, if I can get it started.
Any suggestions would be appreciated, as it seems I have a lot to learn about my new F2.
Thanks guys.
- rey
Any ideas??
Thanks guys.
- rey
RE: Finally Got My F2!!
shouldnt be a problem with the pet ****, you can take the tank off and turn the valve on and nothing will come out because it requires connection of the vaccum tube. my initial thought is its your carbs or plugs. i would probably check for good spark on the plugs first and then dig into your cabrs. theres a great carb cleaning guide in the how-to section found here https://cbrforum.com/m_311016/tm.htm
even if the plugs are the problem i would probably take a good look at the carbs since you just bought the bike
Just got back from work, and have no light to get this project started tonight, so I've been reading through different posts and linkshere and the service manual I downloaded, too.
I've read thru the carb cleaning process. Definately a good link you provided, thank you- will probably tackle that tomorrow morning after I check the plugs. But I've also found a few interesting things in the service manual that I don't understand...
Could the side stand switch have anything to do with this? The service manual describes anengine kill switch attached to the stand - the times I've tried to start it the stand has been down. Though I seem to recall it running before evenwith the stand down. (Don't get me wrong, I have gone back out to try and start it with the stand up, but I'm now down to about zero juice from the battery, so I still get nothing but the engine barelyturning and a dim headlight.) Though I hope to get the battery charged tonight before I start tomorrow's project.
Also, what is throttle stop screw? I see where it is on the left side, but what is it's function?
Some of this stuff I guess might be in the owners manual, not to mention other stuff I probably need to know. Anybody know if there's an online owners manual download?
As always, muchas gracias for all of your input here... looking forward to your responses.
- rey
- rey
Ok, ok, now you guys are going to laugh... But keep in mind, I'm new to motorcycles...
You know the red button on the right handlebar - Engine Stop - Off/Run.
I guess it helps if you have it set to Run.
Me stilllaughing about that helps soothemy newlybroken chain.
I really need an Owners Manual.
- rey
- anybody know where to find the part about replacing/adjusting the chain in the Honda Service Manual - can't seem to find anything about chain/drivechain in the back index
thanks
- rey
thanks
Yeah, it's cool... Little by little it's just introducing itself to me, and even considerate enough to havethings happen within a only few blocks from my house - easy pushing distance.
I'm looking forward to becoming my own mechanic again.
Cool paint there plastikmelter, nice stripes
Thanks to all.
- rey
Thanks to all.
- rey
