I dont see any issue with using the F4i throttle bodies and electronics as long as I could work out any cylinder spacing differences. I would imagine the biggest challenge would be generating a cam pulse signal. Aborted...
You need MS-2(Mega Squirt 2) with some changed pcs and you have good manager to 15 000 rpm it is easy programed and perfect all tuners use this MS-2
F4i injection is ok,need fuell pumpa and some other small things
