Fairing Question??
Does anyone know if f3 plactics will fit on a f2 with no modifications?? Cause i hat the turn signals on the f2 fairings so i want to switch to f3's???
RE: Fairing Question??
why not cut and fill the f2 signals? that is what i did
[IMG]local://upfiles/10054/2D25DBBE268E43B2979E5FF8AA273743.jpg[/IMG] |
dude what kind of front end is that?? that **** is hot?? did u make it?
the f3 REAR plastics will fit!
it is part f2 and part r6. i made it myself in about a weekend
What did you use to make it? Did you plastic weld stuff together or fiberglass or what?
I am almost positive f3 plastic will bolt directly onto a f2. Everything appears to mount up exactly the same on my f2 and f3. The f3 will be getting a 98 seat and tailsection soon. I already have my f3's seat and tailsection on the f2 since it was in better shape. |
Will the front fairing and the side fairings not fit from a f3??
yes they will. you would have to get the upper, both lowers, headlight, windscreen, inner fairings, and both inspection lids. it's alot cheaper to do a little bodywork and remove the f2's signals
