F3 engine in F2 Frame
I know the F-3 upgraded to a wider rear rim, better rear shock, Ram air with bigger carbs....but does anyone know if a 98 F3 motor will bolt into a F2 frame. Seems like a no brainer... but some of you guys know ALL the details. I have access to a F2 chassis, but have an extra 98 motor ready to transplant. Is there something I should be aware of??? Thanking you in advance!
you can put an f3 engine into an f2 frame. the only thing you will have to do is pound in or cut out a small spot on the left side of the frame to fit the carbs.
The f3 carbs have a tps, I wouldn't recommend taking this sensor off.
There are many differences but as far as just putting the motor on the frame and starting it thats the only thing you will have to do.
It's a really easy swap. I've done it.
My CBR is a 1991 F2 with a 98 engine. Or was till I crashed it. :-/
cheers
pat
