F2 won't start and flooded...
Hey, i kept my F2 in a garage for a year or so and now it does not want to start, battery not fully drained and connected to my car with cables so it should be getting enough voltage but it does not want to start, so i took of sparks and they are wet - so flooded - i drained with fire and use metal-brush but it still does not want to start up, not a single remark of starting the motor up, only hear the starter and wait till my sparsk are back wet...
Thanks for any reply, Roman, PRG, CZ
RE: F2 won't start and flooded...
Just a shot in the dark, but maybe the fuel is not good...
Also, jumping of a car is NOT good, even though they are the same voltage. When you checked the plugs did you check the wires...pull back the rubber boot and see if there is white chalky gunk...then you have a plug problem.
You easily could have fried something once connected to the car.
