F2 will not start
Old Apr 9, 2011 | 08:11 PM
Indiana Hurricane's Avatar
Senior Member & 2010 ROTY
Question F2 will not start
A friend of mine did an engine swap. The starter on the new engine was bad. So we put the old starter on the new engine. So we go to push the start button NOTHING. yes the switch is in RUN. I can jump the starter relay and the starter spins and turns the engine over. He has 3 starter relays (used) out of this engine swap deal. We have tried all 3 relays NOTING. Am I missing something ???? Thanks in advance with any help.
Old Apr 10, 2011 | 05:37 AM
buickid's Avatar
Fuel/Air/Spark. Make sure you have all three.
Old Apr 10, 2011 | 09:09 AM
Right now I am not worried about any of that. I need the starter to spin.
Old Apr 10, 2011 | 10:00 AM
damuho's Avatar
In neutral? Also, if the switch is in RUN, is it electrically in RUN (switch is working properly)?
Old Apr 10, 2011 | 02:46 PM
buickid's Avatar
Oh sorry, read it as you could get the starter to spin but nothing happened. Make sure all your connections are secure. Might have to take apart the handlebar controls and clean the contacts out. It can get a little gunky in there.
Old Apr 10, 2011 | 06:10 PM
bowtieboy42's Avatar
I would take a voltmeter and trace all the wiring from the contacts on the starter to the battery and to the starter button.
supermover25
Mar 15, 2019 08:14 PM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
zophill
Apr 20, 2010 07:10 AM
CTcbr929
Jul 31, 2009 12:25 PM
JayBoCC2
Jun 23, 2009 10:23 PM
