F2 Modified with F3 96-98 Fairing
#21
RE: F2 Modified with F3 96-98 Fairing PICS
well i bought the yellow and black plastics off the same guy form overseas... so im curious if u can give me some direction on were to start to mount everything.. i bought the f3 fairings and the rear taillight... i have the headlight. and the f2 fairing stay mount... what else would i need.. which mounting tabs did you have to mess with....
thanks
PAUL
thanks
PAUL
#22
Side Panels are straight fit.
Best starting with the rear bracket for light and then install the rear light fitment along with the rear top panel.
(You need to bend the rear bracket to fit the holes on frame)
Once installed put both front sides on, then rear panels (may need to bend the bungee holders inwards on both sides for panels to mount)
Assemble complete front fairing including headlight in, its a bugger if you try to do it when on fairing individually.
The windscreen from the F3 is last to go on because the holes didnt line up for me as I used the existing F2 bracket.
Once you assemble the front fairing w/ headlight mount it to where you feel comfortable with, mark where you need to drill holes for the mirrors to hold the top section with the plastics.
Remove and drill, be careful !!
Once drilled install front, then attach to your sides then mount windscreen in.
Done.
Gonna get mirrors and finish of the rest of it this Monday.
Done.
#23
Even though I'm not a big fan of the race replica paint schemes I gotta tell ya that's a SWEET looking bike! I salute your patience and ingenuity. I am obviously on a much tighter budget so I've been nickel and diming parts off E-bay and I'm just about ready to begin installing everything. Cheers on the bike. Feels good to do it yourself, huh?
#25
#30
No you need the rear light bracket for the light and I used the rear plastic I got with the kit from ebay.
JUST BEEN TOLD
NOTE THAT WHEN YOU BUY THESE KITS SOMETIMES YOU MAY NOT NEED THIS BRACKET OR LIGHT DUE TO SOME OF THE EBAY SELLERS SELLING THE KITS WITH THE F2 REAR LIGHT KITS, try and ask the sellers first.
JUST BEEN TOLD
